Stop switching Working Directory when saving a Backup
  • December 4, 2020
  • 1414 views
Hello everyone
Is there a way to tell Creo to stop messing around with the Working Directory when saving something as a Backup?
That Creo switches the Working Directory in general is the smaller problem, the big issue is that it changes the File-location of the components that are in session, so you have to erase the entire session or you might mess up your assembly. (Where is the logic? If I save a backup I want to have a backup and not a new Working Directory!)
I know the issue has been around for quite a while, but I only found people complaining about it, and no one who had a solution.
(Maybe I'm just blind)
Regards Daniel
@Daniel_319988 wrote:
Hello everyone
Regards Daniel
it does not make any sense to discuss backup command behavior. According to PTC terminology, it works as expected.
The “as expected” is most interesting part behind the original question.
Dave
