Style Tool Surfacing: Cannot Surface Corners
  • November 30, 2013
  • 2 replies
  • 4274 views
I have been banging my head against this problem for 5 hours now, any help would be greatly appreciated!
I am trying to surface the side of this kitchen mixer. I have my curves made in the style tool essentially making the side into a 3x2 grid, and attempting to fill each part of the grid with a surface (I need to do that so I can deal with the 3 sided surfaces). However, while the middle two fill easily, the corners refuse to work with the message "Curves define more than one surface. Known curve intersections are shown".
I've attached the part I'm working on, can anyone tell me what step I'm missing to getting a surface added in to these corners, or to just surface this whole side?
Thank You!!!!
I cannot open the academic version file. Care to show a picture?
Have a you tried a simple corner round?
Pgsys1-VisitorAuthor
That's odd, I wonder why that is?
Here is a side view: The bottom right is the one I'm trying now but all the corner peices don't work. (I know I need to do some fiddling around with the 3 sided patches to make them work properly).
Here's an angle view so you can see the shape of it.
Thanks!
Take a look at boundary surface with tangency.
Full verions of Creo cannot open academic. This is normal for some silly reason.
The fix ended up being splitting the centre (or the top) curves so that they no longer could define more than one surface. What a maddening problem! The freestyle feature worked in the meantime.
Thanks for the suggestions everyone!
