Sweep Surface Question
  • June 6, 2019
  • 2287 views
Hi Creoes,
I have a question how to create a surface using only 2 splines - one for shape and other for trajectory?
It is possible in other CADs but Creo.
Thank you,
Arek
Best answer by MartinHanak
using sweep options you can create geometry whose sections are not perpendicular to the trajectory.
I uploaded test model. Look at it.
ArekTRI1-VisitorAuthor
Hi @MartinHanak
Really helpful attachment.
Another issue (for me) is, Sweep command forces to create the perpendicular section to the trajectory line/spline what gives a different result.
In SW/Onshape or different CADs, it is possible. Onshape below.
Anyway, thank you very much.
Arek
