Hello again PTC-Community!
I am trying to make a template out of a sick, but it seems Creo doesn't want me to.
It just goes from this (which looks fine to me)
To this...
Which does not seem to be right.
Anybody know a solution to this?
thanks, guess i'll give our distributor a call about it, since we have a premium subscription with them!
EDIT:
guess i was actually just stupid..
made a silnge part as template and boom it worked..
Hi do you mean that the pattern result is different from the previous of the pattern feature?
Yeah, exactly..
thank you for your confirmation.
Have you try that same pattern on a model from scratch or does it happen solely on that model? (need to sort out if this is a general behavior or specific to the model / workstation))
Unfortunately i can't recreate the issue now.
but also, when i want to do the template by measurement i can not go in the direction where the 6 would be.
this needs a closer hence, i recommend you file a case at support: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
EDIT:
