Tolerance Analysis STP files
  • September 14, 2017
  • 2036 views
is it possible to do a tolerance analysis with step files? I got a assembly with two bearing models from a supplier. The geometry is a imported feature so i can not change any dimension, eg the length of the bearing.
How can i do a tolerance analysis with imported features or step files?
thanks
Simon
If you have the flexible modeling extension you can make dimensions that are changeable.
You can change lengths/ radii/ number of features, anything.
try
https://www.youtube.com/watch?v=MdtUzCv_vWw
Erik
