Tool for copy autocad sketch to creo 2 sketcher?
  • April 22, 2014
  • 4 replies
  • 5482 views
Dear Everyone,
Anybody know how to copy a sketch from autocad drawing to creo sketcher ,because some of sketches are standard and i want to copy it from autocad to creo and then directly extrude it.
Manish
I don't know if this is the best way, but I've saved AutoCad files off as dxf files and then brought them into Pro_E/5.0 in the sketcher mode. I've also taken Pro E files into AutoCad as blocks. AutoCad 2012 and new have import and export modes that will probalble let you export files in other formats that may work in ProE. I'm using Creo 2.0 now but I haven't tried bringing an AutoCad file in lately.
In Pro/5 I bring in acad drawings into part mode by insert shared data, This way nothing distorts or changes unexpectedly. Then you can go into sketcher and referances the edges you want to extrude.
Hope this helps.
As a matter of fact, this is a good idea,i strongly support it
Clicket sketch, when sketcher environment activated, click on file system, set the type to all files and select your *.dwg file.
mgupta-41-VisitorAuthor
Dear Jayant ji ,
I found it working but it only called the lines and circles not the text that the most important thing for a company logo ,it almost standard and it will take much time to redraw it , i have a company logo in exploded form ,now i want to call it to make visible in the name plate model .
Manish
Dear Mr. Manish,
I Think You might want to have the logo on the drawing template not in the sketcher? If so then try to insert the logo in the drawing in picture format otherwise the hatch will come in exploded form.
Jayanta Sarkar
