Try changing Num Digits under Sec Environ.
  • March 11, 2014
  • 4715 views
Working in Creo 2.0 Sheet Metal and I'm trying to add a dimension and I'm getting the following message "Could not add selected dimension. Try changing Num Digits under Sec Environ."
How do you change the Num Digits under Sec Environ? I've searched here and the interweb and the only thing I found is somebody asking this same question back in 2008 on another forum but it was never answered.
Thanks...........
Best answer by TomD.inPDX
There is no "environment" in Creo. It is actually in options under "sketcher".
Thanks Antonius, problem is resolved.
