Unable to alter Line thickness in View Due to Hatching
I see that you can delete hatching from a 2d section view. I'm not sure how you would even generate a cross section on a 2d model. However, after creating a 3d section view, I am not able to reduce the line thickness. The message states: Input contains elements of wrong type. I presume this refers to the hatching - as that is the only difference between the views. Please advise how I can turn off the hatching - alter the line thickness - then turn the hatching back on. Or is there some other way I can achieve thinner lines on the prints?
