Unable to create a "proper" offset of curves
I'm wondering if this is a bug in Creo (I'm using 9.0.1.0), or if I have mistakenly set a stupid settings...
I can't seem to create offset curves in the manner that I've been for decades. What I consider standard process to make an offset is:
(1) Select a chain of curves, either one by one or with the chain selection (shift-select).
(2) When I'm done selecting curves, an arrow shows me the direction of the offset.
(3) I enter a value and I now have a chain of offset curves, comprised of individual curves corresponding to each of the curves I selected in step (1)
What I'm seeing this afternoon is what's shown in the image. I can kind of pick a chain, but the offset curve it creates is a single curve, no matter how many entities are used, and I can't access individual entities in the curve (i.e. delete an unneeded curve in the chain so it can be replaced, or trim a curve with another entity, etc.).
Is there a setting I inadvertantly toggled that activates this type of behavior? I wasn't seeing this in the morning, but now I'm doomed.
Incorrect Selection Method
