Hello everyone
I have an assembly with a master rep., and when I open it a lot of the parts are hidden.
If I unhide the parts, saves the assembly, close it and open it again the parts are back to hidden again in the master rep.
It is pretty annoying because my other simplified reps does not look wright before I unhide the parts in the assembly.
Any suggestions to what I am doing wrong here?
Best regards
Claus
Switch to the layer tree, right click, and 'save status'. Then save the model and re-test.
Hi Tom
It worked, thank you :-).
Have a nice day!
Using hide is not really a Simplified Rep function so that hidden component will be hidden in ALL your REP's. That may be what you want but I just want to let you know.
