Updating from Creo 4.0 to 7.0. How will my 4.0 config.pro function with 7.0?
  • December 10, 2021
  • 3 replies
  • 1081 views
I am using Creo Parametric - Release 7.0 (connected) 7.0 7.0.5.0
I am switching from Creo 4.0 to Creo 7.0, will the majority of my 4.0 configuration options function in 7.0?
Or do you recommend starting a new config.pro?
    Just use the existing one.
    After starting Creo 7, open the configuration editor and see if any of the settings have a red flag, indicating they are no longer valid.
    22-Sapphire I
    December 13, 2021
    @JOHNKASTEN
    You can copy the config file from Creo 4.0 and use in Creo 7.0 by placing that in start in directory of Creo 7.0
    Thanks.
