Use file .dtl in PTC Creo Layout
  • October 12, 2015
  • 3 replies
  • 2006 views
Hello everyone,
PTC Creo Layout is able to read a config.pro but I cannot apply drawing/detail option (.dtl). Can you had it in PTC Creo Layout ? It can be very useful to create conceptual design and basic drawing.
Here is something from the support :
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS60117
Alexandre is absolutely right.
Adding that option in PTC Creo Layout could solve many problems.
Without the dtl file in CREO Layout it is not possible to meet a specific normalized style. It could be really useful to use the same style between CREO Layout and CREO parametric drawings. That's why .dtl file for format layout is needed.
Here is the same idea Some obvious "ideas" (p. 2.5) and other necessary ideas.
