Visualizing geometric tolerances in 3d view.
In this part I have set some gtol attached in the dimensions.
But, as you can see in the 1st picture, they are not visualized normally, but only if I edit the feature where there are the dimensions they are referred.
This because I have created Gtol on a dimension.
If I created the gtol "with leader", in the 3d view it would be visualized.
- Is there a manner to visualize the gtol of each kind?
- Is there a manner to visualize the gtol on the dimensions if I select them in the model tree?
Thanks.
