When will PTC introduce extrude normal to surface of a wrapped sketch?
A google search indicates that since before 2010 CREO has been incapable of offering direct extrusion from a wrapped sketch. There are various work-arounds that exist which largely requires minimum 3-4 steps and it is not very stable. The most recent "solution" from PTC is CS82388 which takes 2 seconds to modify some parameters to see why it is not a solution: it does not translate/wrap around the cylinder beyond 180 degrees. In Solidworks you can literally extrude/cut directly from the wrap tool beyond 180 degrees, this is in just 1 step.
So, PTC, you are very much behind your competitors, and have seemingly ignored your users for over a decade - when will extrusions from a wrapped sketch be introduced as it is not in CREO 10?
Article - CS82388 - How to wrap and extrude text around a cylinder in Creo Parametric (ptc.com)
examples of solidworks:
