Windchill smartlock and regeneration in Creo
  • September 18, 2025
  • 3 replies
  • 926 views
Why objects which is regenerated in creo changes it's state from
to
after regeneration.
Object is read only why has it been chagned during regeneration?
Best answer by Van_AG
Open and regenerate the assembly
Execute the Tools > Compare Assembly command
Select the same assembly from the workspace.
Creo will show you what has changed after regeneration, and you will be able to locate the problem
In my example, the AUTH_NAME parameter gets its value from PTC_WM_MODIFIED_BY through an equation
According to PTC training materials
Locking a CAD document in the workspace sets a read-only status on the content stored in the local
workspace cache.
It may be desirable to make an object read-only for any of the following reasons:
β€’ To reduce the number of times that the Conflicts dialog box is presented for objects that are
not intended to be modified.
β€’ To provide better visibility into changes made implicitly by the CAD application. For example, you
are alerted to unplanned or unexpected changes that are required during regeneration.
β€’ To prevent the object from being accidently modified.
This indicates that the model is not completely locked in the Creo session.
"Works to product specification"
Set regenerate_read_only_objects to NO in your config.pro
We can’t change this. The parameter is set to YES because it comes directly from the drawing.
We use parameter in relations whici part_number = REL_MODEL_NAME
This parameter is hown on drawing. And if this parameter id used by instance of family table. then after regeneration each instance get's number of generic. Total disaster happens then when manufacturers get's our drawings with generic numbers in it.
What version of Creo are you using?
Are you using Windchill with your data?
Are these family tables saved in the current version of Creo?
Try this hidden config.pro option.
Article - CS170675 - Definition and values of hidden config option regen_read_only_insts in Creo Parametric 2.0
Creo verson 11.0.3.0
Windchill version 13.0.2.4
all objects has been created in new creo and checked into new windchill. Everything is stored and created in versions where it's used
According to the: https://www.ptc.com/en/support/article/CS32596?source=search
didn't help 🫠
Catalina
Community Moderator
September 30, 2025
Hi @ilyachaban
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Moderator
There is no solution for now. There is also parallel branch together with PTC Support so if there will be any aplicable solutions i will write it down here.
