assembly copy
Hello.
I have assembly with subassemblies and need to create a copy of one of the subassemblies. The top assembly is open.
When I open the subbassembly and use save a backup and point to the backup directory it saves all the assembly include all the parts.
It's ok but the opened subassembly and parts in the session points afterwards to the files in the backup dir. It means when I continue to work with the subassembly (or assembly) the changes are saved to backup dir. and not to the working dir.
(note from help: "If you make changes to a model after backing it up and then save the model, the changes are always saved in the backup directory.")
To continue working I have to erase the top asm from the session and open again....
Is it possible to do this without reopening asm?
thanks for help
michal
