can simulation controled by parameter?
  • December 16, 2011
  • 3021 views
I defined the motor profile "initial angle" using parameter "d" which is 5 in the local parameter list. when I chagned the value of "d" to 10, it is not updated in the definition of the motor profile. the initial angle was still 5, except you modify that manually by inputting "d". it can not controled by the parameter?
Can anyone help me with that? i hope the motor initial angle can change with the assembly condition.
thank you
linda1-VisitorAuthor
the question is not clear?
what i want is to use the parameter to control the rotation angle of a motor profile for the simulation, the parameter is controled by a relation, which means it changes when design parameter changes, I hope the
rotation angle can updated accordling not input manually.
i will be very appreciated for any comments on that,
thanks
Hi Linda...
I actually did look at this. Apparently I forgot to respond with my the results. I was actually unable to control the rotation angle with a parameter. I was able to assign a servo motor and assign the starting angle. When trying to use the variable, the system didn't seem to like it. I'd enter the variable name and it would be replaced by the current value of the variable... yet when the value changed, the angle did not.
It seems strange to me that you can't control the motor with a parameter variable or relation. I was able to use a relation to control the motor with the user defined profile option... but not in the way you need. Maybe if I use a force motor instead of a servo we'll have better luck.
If you have any other information about your scenario, please pass it along. I haven't tried controlling a mechanism in this way before but maybe someone else has?
Thanks!
-Brian
hi
we have the same problem. the motor profile can not be controled by the parameter. it uses the current papameter value when it is defined. It can not update when the parameter changes.
I use wildfire 2, so i can not access user defined profile. if you can use relation in simulation modular, can you use relation dxx=ratation_angle like we do in 3d modelings? in that way , it should be able controled by parameter.
I want to check the changes of minimum compression when disc rotates for a buttetfly valve design. I can measure the enter angle, the exit angle, using the difference to control the velocity. It is a pity that whenever the design changes i have to manully repeat the motor profile definition to have a correct motion analysis. In fact , i have a family, so i have to redefine each instances.
I will try to use force motor, to see what we can do about this issue.
thanks very much.
linda
