7-Bedrock
November 8, 2021
can't make drw file
  • November 8, 2021
  • 2 replies
  • 1552 views
I am using Creo Parametric - Release 6.0 (connected) 6.0 6.0.6.0
Can't make drw file at some part, ok button 'color is grey
Here are the errors that I faced
n.a
    Best answer by JOHNAHN
    Hello
    This is s.o.ahn, post above issue.
    Thanks for your replay.
    Your guessing is correct
    I had found the solution, that is same file name  being in some fold.
    One more time thanks for your replay.
    Best your regards
    s.o.ahn
    Your post is missing a screenshot of this error.
    Like @VladimirN said, you haven't attached any screenshot, but if I had to guess, I'd say that you might have activated "Use drawing model file name" option when choosing Drawing as a new file but in the second window, where you configure drawing details (like template, format etc.) you haven't defined a default model, so there is nothing to copy drawing file name from, thus preventing you from creating a drawing.
    JOHNAHN7-BedrockAuthorAnswer
    7-Bedrock
    November 8, 2021
    Hello
    Best your regards
    s.o.ahn
    Glad you were able to sort it out 🙂
