creo 3.0 ecad import
Hello Experts,
I was wondering if anyone has run into this issue.
When importing emn/emp files in CREO 3.0 if the "ecadname" in the ecad_hint.map is longer than 31 chars its truncating those name for the session and the resultant is that the mcadname to be used from the library is not brought into session since the ecadname truncation doesnt carry over to the emn/emp files.
This behavior didnt exist in CREO 2.0. An SPR 5720922 has been filed but I wanted to reach out and see if anyone had this issue and found a suitable workaround.
Anil
