creo agent did not initialize correctly
  • August 3, 2022
  • 2 replies
  • 3317 views
I am using Creo Parametric Release N/A and Datecode N/A
If there is an environment variable TMP is set to a readonly folder, creo agent did not initialize correctly. This shoud be mentioned in
https://www.ptc.com/en/support/article/CS185244
Best answer by AndreasVogt
The information is added to the CS. So this is solved for me.
Dear @AndreasVogt
You found that when an environment variable TMP is set to a read only folder the Creo agent does not initialize correctly and that the fore mentioned article will benefit from this information.
Thank you for your contribution. The most efficient process to notify directly the right person ie the author of the article, is to file an article feedback by clicking the button at the bottom of the article:
AndreasVogt10-MarbleAuthorAnswer
