divide at intersection
What happened to divide at intersection in Creo 2? I have two lines that intersect each other. One of the lines (the horizontal line in the picture) is already divided into two separate segments. Whenever I try the new Divide command, it does not divide the other line (the vertical line in the picture). The help says:
To create a divide at an intersection, click near the intersection and Creo Parametric automatically snaps to the intersection and creates the divide.
I don't see any way how I can control which lines it tries to divide.
Why was the divide at intersection feature removed? I also wonder what happened to the trim to bound command
