error with distributed Pro/Batch
Hi everybody
I recently started using distributed Pro/Batch for the generation of .dxf files from all .drw files stored in our repository folder
The .dxf generation process works ok for parts.
However when I try to generate .dxf files for assemblies the conversion fails
On the log I get the following error:
OPERATION | STATUS | COMMENTS
Connected to Pro/ENGINEER | Successful | C:\Program Files\proeWildfire 5.0\bin\proe1.psf
Reading Task Type Definition | Successful |
Copied configuration objects | Successful |
Search Paths added | Successful | "C:\Users\AP\Documents\...\hardware\mechanics\proe\"
Load Model into Pro/ENGINEER | Failed | [-4] Error: Incomplete input data.
Task Status : Failed
Any clues on how to solve this issue?
Thanks in advance for any help
Alberto
