export BOM to excel format
DennisRehmer
To all,
We are using WF4.0, and I was wondering if there is a way to easily export a BOM into an Excel format.
I would like to include in this things like the part number, description, quantity and maybe other pertinent information. If you do the Pro/E Info > BOM it is in a text format and does not have any information other than the part number and the quantity normally.
Dennis
6 REPLIES 6
Dennis,
you can specify user defined contents of textual BOM using special format file and bom_format config.pro option. Try to look into PTC Help.
Martin Hanak
Martin Hanák
Thank you for your suggestion.
Hi!
You can select a table in drw file ans save as *csv file.
You can open csv with excel, openofice, libreofice etc
Thank you for your help on this.
I set the model tree to display the parts and content of interest, then save the tree (not the tree config) to a text file. It gets saved in the start-in directory. Import the file as text and use fixed width to select the fields or create a macro to parse the lines.
It's necessary to expand groups and patterns; these become markers which can be helpful in determining where a component is used.
Thanks for the suggestion.
