export flat harness
Marshdamp
7-Bedrock
export flat harness
I have a need to export a flattened harness to a step or iges file and can't quite get it to work. I am on Creo 4.0. When I bring up the manufacturing file there is an export button in the file-->save as menu but it doesn't do anything so I tried just file-->save as. With save as I can get a step or iges file but in both cases the bundles don't show up in the resulting files. If I check export cable surface in the export options I get thin lines between components and a lot of big looped curves. Anyone have any ideas on how to export a flat harness assembly?
0 REPLIES 0
