Does anyone know how to change the default font on the drawing?
Creo supports TTF fonts, but you will need to copy the fonts needed to a directory that Creo uses.
See this thread for details on how to manage TTF fonts; @MartinHanak has provided a good summary.
Solved: Drawing and Modeling fonts? - PTC Community
This video explains how to set the font up.
How to change default fonts for drawing text in Cr... - PTC Community
Thank you, do you know how to change to Arial wgl because i didn't find it ?
Thank you
