hiding the display of height restrictions in Drawings in WF3
  • November 7, 2011
  • 4677 views
Hi ,
How to hide the height restrictions from display in Proe drawings.
this is needed because of the translated pdf, cgm file contains these lines which are not required.
Awadhesh
Is this still a problem for you?
Sounds like a format issues... Can you change the format to not show those lines?
Hello Craig,
This issue is still not resolved.
Do you mean I need to change the Frm file that is being used by the drawing ?
Or you have any setting through which i can disable the display of the height restrictions.
-- Awadhesh
Craig, I am not a designer. for proper translation I need this thing hidden. Let me know the steps if somehow i can hide it .. Thanks
