how to add part's relation with manufacturing relation
  • April 30, 2014
  • 1275 views
i had made the relation in expert machinist in proe and in part module like 1.total material cost and 2.total process cost (milling) so how do i add this two relation and make it to add and display it in drawing template.
will you provide me a suggestion
To show a parameter (e.g. param_name) on a drawing in a note, you can use the syntax:
&param_name
If there are multiple choices for the source of the parameter (drawing, drawing model, other model in drawing):
&param_name:id
(where ID is the session ID of the model or D for the drawing)
For a drawing template / format you will probably have to put the placeholder for the parameter into a drawing table, as otherwise Creo assumes (because initially there is no model assigned), that it's a drawing parameter you are after.
