how to avoid planes to show-up when I rotate a view in drawing (every single time)
- August 19, 2024
- 2 replies
- 2915 views
as far as I know it's a problem that exist at least since PRO-E WILDFIRE 3.
still present in CREO 9.
every time that I edit a view on the drawing, to rotate that view (i.e. a 3D view of the assembly or part), the planes show-up and I have to manually remove the visibility of these planes.
it's happening every single time.
if I toggle the visibility off then close the editing view (Drawing View) then I'll redo it again, the problem came back again; rotating the view toggle the visibility of the planes back again and I have to remove manually.
the problem is limited to when you use the "View Orientation > Angles" part to orientate the view.
if you rotate the view with the other orientation method the problem will not appear.
before asking there I tried to read articles, search on-line etc. and I can't understand if it's the cad not properly set-up or it's something that has been designed that way.
maybe it's me that wasn't able to find the right search keywords?
I tried also searching for options inside the cad that maybe solved the problem, but so far it has been unsuccessful.
I also tried to search the option list on the manual (so you cant' tell me to RTFM; maybe RTFM better, but please tell me also where to search LOL).
it's tedious, after all of these years, to have the same little problem presenting again and again multiple times a day.
it's like a little drop of water that on the long run, became unbearable.
thanks for your help.
