how to set ModelCheck NOT in a separate window? Creo7
MarkHeinze
We only just now upgraded from Creo 4 to Creo 7.
When running Model CHECK now, it opens in a separate stand alone window, which with multi screens pops up most often in a screen you are not working in. Is there a config setting to get the MC window to open "integrated" (not a stand alone window) in the model graphic window the way it was in Creo 4?
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry. It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Andra
With Creo7, the ModelCHECK dialog/results box opens in a separate window. In Creo4, it opened integrated similar to how the workspace dialog as shown in yellow in the picture above. How to get mc integrated and not open in a separate window for Creo7? Is there a config option to set this?
