i need to unbend the model
  • January 31, 2018
  • 2209 views
I need to flat or unbend the part,Here i attached the model
The deployment of this model by standard means is not possible.
You should create this model from parts. Or use the FTI Fastblank Integration extension.
PTC Creo Parametric & FTI Fastblank Integration for Blank Devlopment
JAK1-VisitorAuthor
Thank u so much..I will try and let u know later.
