material appeareance - no color when assigning material
Dear All,
creo material appearance
I observe strange behaviour of creo in assigning colour that match material's appearance setup - part turn white after assigning material.
/my version 5.0.1.0, but it also was in previously installed 4.0/
Behaviour:
- Assign material to a part
- There is no colour - part turns white from default colour
- I modify the appearance /default appearance/
- Save this material - by save to library
- Assign modified material to a part colour was taken from the material appearance correctly
- When I turn off the creo and reopen it
- Assign same material modified before
- Part turns white In material properties of this material
- Nearly all colours in material appearances window, turned white
In my config.pro appearance catalog, color.dmt file - is set to default Creo 5.0.1.0\Common Files\graphic-library\appearances
How to fix it? Is there any options that controls this behaviour?
Thanks in advance for your help.
Regards!
