material appeareance - no color when assigning material
  • September 12, 2018
  • 6164 views
Dear All,
 creo material appearance
I observe strange behaviour of creo in assigning colour that match material's appearance setup - part turn white after assigning material.
/my version 5.0.1.0, but it also was in previously installed 4.0/
Behaviour:
  • Assign material to a part
    • There is no colour - part turns white from default colour
  • I modify the appearance /default appearance/
    • Save this material - by save to library
  • Assign modified material to a part colour was taken from the material appearance correctly
  • When I turn off the creo and reopen it
  • Assign same material modified before
    • Part turns white In material properties of this material
    • Nearly all colours in material appearances window, turned white
In my config.pro appearance catalog, color.dmt file - is set to default Creo 5.0.1.0\Common Files\graphic-library\appearances
How to fix it? Is there any options that controls this behaviour?
Thanks in advance for your help.
Regards!
I guess that color definition must be present in global.dmt file.
Same thing is happening to me. I can see that the global.dmt is not getting updated when I define the material appearance. Set the global_appearance_file option and made sure I have write access the the file too
Is this a bug?
Creo 4.0 M070
Is this a bug?
Creo 4.0 M070
in the past (in Creo 2.0) I modified global.dmt file manually ... see below described procedure:
  • I defined new model color
  • I opened Appearance Manager window ... new color was located in My Appearances section
  • in the same section I clicked File > Save As and entered _MH_appearance name ... all appearances were saved into _MH_appearance.dmt file in current working directory
  • I opened _MH_appearance.dmt file in Notepad++ selected color definition (see below shown example) and pasted it into globat.dmt
  • I deleted _MH_appearance.dmt file
# material name
material_name "ref_color54"
# material label
material_label "MH"
# material description
material_description ""
# material keywords
material_keywords ""
# ambient color
ambient_color 0.630000 0.330000 0.730000 1.000000
# diffuse color
diffuse_color 0.630000 0.330000 0.730000 1.000000
# specular color
specular_color 1.000000 1.000000 1.000000 1.000000
# diffuse
diffuse 0.850000
# ambient
ambient 0.300000
# shine
shine 0.350000
# shine intensity
intensity 0.300000
# reflection
reflection 0.050000
# bump_type
bump_type 0
# amplitude
amplitude 1.000000
# scale
scale 0.100000
# exponent
exponent 3.000000
# rotation
rotation 0.000000
# color_tex_type
color_tex_type 0
# color_tex_scale
color_tex_scale 0.100000
# color_tex_rotation
color_tex_rotation 0.000000
# decal_type
decal_type 0
# transparency
transparency 0.000000
# fresnel index of refraction
index_of_refraction 1.000000
# fresnel reflections
fresnel_reflections 0
