modify conflict options choices
To all,
I was wondering if there is a setting, or where the option might be, to turn off certain selections when you go to modify a part that is not checked out, so the user cannot select either of these two.
- Revise and Check out now
- Revise and check Out Entire Family
We do not want anyone to be able to revise a part/assembly unless thru the change managment process, which is WindChill in our case. Attached is a screenshot of what I am referring to.
If this is not in the correct location for someone to answer, if it can be shared to who would be able to best respond, feel free to do this.
Thank you,
Dennis J Rehmer
ABB
