multi bend
  • September 7, 2017
  • 4842 views
hello all . i hadd plate ,i want to make 3 bends in differient positions.ihad made two but the last can not exexute till i delete the other bend >please help .see attached files
Best answer by psobejko
This sequence worked for me:
 11
22
3 - bend using "up to end of surface" option3 - bend using "up to end of surface" option
4 - add an extrusion to form a flat section that...4 - add an extrusion to form a flat section that...
 ... can be bent (again using the "to end of surface" option)... can be bent (again using the "to end of surface" option)It's definitely not intuitive...
thanks friend.but after applying bend 1  and bend 3  the position of bend 2 is flat.look at pic belowbend 2-1.jpg
