open native multi-body solidworks2022 part file in creo9
  • July 22, 2024
  • 1891 views
opening native multi-body solidworks2022 part file opens as an assembly in creo9
should open as multi-body part file ?
thanks
Rich
tbraxton
rburk13-AquamarineAuthor
I followed the settings in Article CS368204, does not open as a "Solidworks Part file with multi-bodies"
- opens as an assembly with multi-bodies
tbraxton
Note these conditions for opening SW files, if you have any import bodies then it will open as assembly in Creo.
When a SolidWorks part consists of the native body and one or more import bodies, the part explodes into an assembly during its import. The native body and the import bodies are imported as individual components of the exploded assembly, a component for each import body and the native body. A SolidWorks part with only import bodies, without geometry in the primary database, also explodes into an assembly on import, with a component for each import body. A SolidWorks part with a single import body, without a native body, is converted to a Creo part.
