"Make Transparent" command and Geometry Filter
  • February 5, 2023
  • 3762 views
I can't use the command MAKE TRANSPARENT (I don't mean the Transparent command to set the display state) with the Geometry filter. I must obligatorily select Body as filter.
But I can add that command in the mini toolbar in that Selection item...
Is there a way to use Make Transparent with Geometry filter?
Best answer by mneumueller
No, I think the actual behavior is the intended behavior. If you select geometry, in assembly you act on the part transparency, inside a part you act on a body transparency.  If you select the body explicitly, then of course the command always relates to and acts on the body
what Creo version do you use ?
In Creo 9.0 I have Geometry filter selected when working on part. When I select Body using Pick From List command the mini-toolbar is displayed containing Make Transparent button.
I use 8.0.7.
If I select Body that command appears also to me, but I wonder if there is the possibility to use the command simply "touching the surface" with the geometry filter activated.
tbraxton
Creo 8 transparency control for quilts/bodies.
@mneumueller   has presented the details of how to use the UI elements in this video.
https://www.youtube.com/watch?v=OnbiGMFDAmQ
