needs solution with 3.0 if possible give part file for better understanding
It is possible to create this geometry with Creo parametric 3.0. I would use 3 sweeps, one each for proximal and distal non helical trajectories and one helical sweep for the coils to connect them.
I modeled it as attached, hopefully it gives you some idea.
cant able to open it... can you mail me on galande96@gmail.com
It's Creo 4.0 file. What version are you using?
I was like....what the h3ll is wrong with this drawing....then I realized it's 1st angle projection. Man, I can;t believe anyone still uses this, it's SO bass-ackwards....
