repeat region filter limited to 80 characters
  • July 25, 2022
  • 3 replies
  • 2440 views
I have a filter condition which exceed the limit of 80 characters. (&asm.mbr.name==...)
The opposite condition doesn't result in a shorter formula.
I tried to use "or" ( | ) but didn't success.
&asm.mbr.name == *val1*, *val2*, *val3*,...
|asm.mbr.name == *val11*, *val12*, *val13*
Do you know a solution ?
Thanks.
discuss your problem with PTC Support.
You have not specified what version of Creo you are using, so perhaps the repeat relation functionality has changed since Creo 4.0.
Either way, maybe the following (extracted from a pertinent article, CS150475) may be informative:
How to write a repeat region relation that uses a wildcard in Creo Parametric
Applies To
  • Pro/ENGINEER and Creo Elements/Pro Wildfire 2.0 to Wildfire 5.0
  • Creo Parametric 1.0 to 4.0
Description
  • How to write a repeat region relation that uses a wildcard
  • It always gets the wrong result when add a relation in repeat region
Cause
Resolution
Give us a better description of what you are doing with the relation?
Relations have always been limited to 80 characters.
Nicolas_G13-AquamarineAuthor
Hello @BenLoosli ,
@MartinHanak his right.
I have to write a relation like that:
&asm.mbr.name == *val1*, *val2*, *val3*, *val4*, *val5*, *val6*, *val7*, *val8*, *val9*, *vala*, *valb*, *valc*, *vald*, *vale*, *valf*, *valg*, *valh
But it exceed the limit of 80 characters.
Best regards,
Nicolas
@Nicolas_G wrote:
Hello @BenLoosli ,
Best regards,
Nicolas
you can use procedure similar to the following one:
Define repeat region relations
Define filter
The above mentioned settings are used in uploaded Creo 4.0 drawing.
