scaling Curve from Equation
ProFeature
Hi
I created a curve from equation.
x = sin(t) + 2 * Sin(2*t)
y = cos(t) - 2 * cos(2*t)
z = -sin(3*t)
I tried Scale Model but it doesn't work on a curve from an equation.
Is it possible to scale the curve without modifying the equations?
kdirth
(To:ProFeature)
Select the curve then Copy Geometry and, under Options, select No Dependency.  This creates a copy of the curve that no longer references the original.  If you then scale the model, the original will stay the same and the copy will scale.
tbraxton
22-Sapphire I
(To:ProFeature)
You have the equations defined. Just multiply each equation by a scalar value to "scale" them. If you explain the constraint of not modifying the equations that is probably useful to someone finding a workaround.
To double the size use scalar value of 2
i.e. for the X component: 2*(sin(t) + 2 * Sin(2*t))
Scaler =1
Scaler=2
Involute Development, LLC
Consulting Engineers
kdirth
(To:ProFeature)
tbraxton
22-Sapphire I
(To:kdirth)
Applying a scalar to the equations (without editing the equation in the curve feature) it is possible to scale the curve size. By using a scaler parameter in the curve definition, the curve size can be scaled by modifying the parameter value. This establishes a single feature that can generate infinite sizes of the curve on demand and is parametric.
Does this approach satisfy the requirement to not change the equations?
The red rectangle is shown for scale reference.
Thank you 🏆
