sheet metal half-shear button
  • April 10, 2020
  • 2 replies
  • 6947 views
Hi ... CREO4 user ..... trying to create a half shear button in sheetmetal part ... what is easiest/best way?
Best answer by pausob
In the sheetmetal, use sketched form, change type to "piercing" instead of "punched" (2nd icon in the ribbon).
Then just sketch a circle...
BTW ... I tried to do a "sketched form punch" .... it made the small half-punched hole in the front surface, but creates a larger (added sheetmetal thickness) plug diameter on the back surface.    Hole diameter in front and plug diameter in back should be the same on a half shear button
Not sure what you mean by a half-sheer button, but how do you punch material and get the same diameter on both sides of your sheet?  The material has to be deformed someplace and I would expect the back side to be larger than the punch by the material thickness.
No ….. this is what a half-shear button is ….
pausob19-TanzaniteAnswer
Perfect …. thank you very much !!
