spline - to impose tangency conditions in the splines at the intermediate points
  • October 2, 2023
  • 2 replies
  • 3261 views
Hi, I still use the WF4 version and I would like to know if on the latest versions of Creo Parametric it is possible to impose tangency conditions on lines/planes/curves in the splines at the intermediate points as happens for Catia.
The curves referred to are external to the spline profile.
To better understand what I mean, look at this
https://www.youtube.com/watch?v=Ba8ycG1dPtA
at minute 30.45
forget the rest
You can also get there by building but it's quicker that way
HI
kdirth
As of 7.0, you cannot impose constraints at interpolation points on a 3D spline.  You would have to create multiple splines with constraints on the end points and then create a composite curve.
tbraxton
The Creo features that would be an analog to the CATIA functionality you are looking at are ISDX curves and surfaces. ISDX curves have more control available to them than "regular" splines. You must of course have access to the ISDX Creo extension to use ISDX features.
mamobono10-MarbleAuthor
I tried using Style but I can't impose constraints on the intermediate points.
See Attachment
Maybe it's my old WF4 version that doesn't allow it.
HI
what is interesting is that they can also refer to external curves and not only to planes or lines that pass through the intermediate point
Hi
