step_with_dialogs
RaphMORIN
step_with_dialogs
Hi, I'm cleaning my config.pro file. It has very old options such as this one below which seems to be a hidden one. I didn't find anything related. Anyone knows what this option does ?
5 REPLIES 5
Seems to be an option that has been hidden since Creo 1, or at least that's as far back as I can find it. Nowhere do I see anything documenting what it does, though. Perhaps in the long ago STEP file output just created a file and didn't provide a means of setting options? Maybe in the early days of STEP there weren't a dozen or so different standards for STEP?
tbraxton
(To:RaphMORIN)
This option is still available in Creo 11.0.1.0.
I believe it is used to invoke dialogue boxes during the STEP import/export process. Obviously, you can test this by deleting it and importing/exporting a STEP. Hidden config options are usually not officially supported by PTC and are used for internal development purposes. I think you should be able to delete this option without causing any issues. You can always put it back in the config if needed.
Involute Development, LLC
Consulting Engineers
KenFarley
(To:tbraxton)
Just out of interest I looked further back and this has been hidden since Wildfire, too. Seems like an "orphaned" option. Maybe it doesn't do anything? I don't have it in my config.pro and STEP export works fine.
according to https://creosite.com/index.php/configuration/config-pro-option-search/?search_term=step_with_dialogs&or=1&version=creo11&db=all&mode=all page the option is hidden. Please ask PTC Support for more information.
Martin Hanák
Well, tested import and export without this option and I can't notice any difference. I think I can safely delete it. 😊
I was asking for knowledge reason. I'm going to ask support to know more.
