tangent model quickstart project
I am sitting here going through the quickstart projects to re-learn to operate Creo again. I had loaded the latest version of Creo Elements/Direct Express version 6. I have discovered that the qucikstart project "Create and modify a tangent model" does not work correctly when resizing the model at the end in version 6 but I had the older express version 4 on the machine and tried the same project. It worked as the video shows. I could not figure out how to get version 6 to produce the same result as video. Maybe a bug of some sort.
