turn off annotation display by default
  • January 14, 2020
  • 4429 views
Can someone tell me how to turn off 3D Annotation Display by default?  Every time I open an assembly the Annotation Display is set to show.  How to I set it to Hide when I open a file?
Go to File - Options - Entity Display and find "Show Annotations and Annotation Elements", uncheck the box and when you push OK, it should prompt you to if you want to save the settings, choose yes and *hopefully* you will have a config.pro you can save to.
wrbird1-VisitorAuthor
Thank you!
