unit tolerance in Creo 6.0
  • July 10, 2019
  • 3 replies
  • 9864 views
How do I do unit tolerance in Creo 6.0?
2-Explorer
November 7, 2019
I have this same question but for Creo 4.0.  Where the heck is it?
18-Opal
November 8, 2019
Please elaborate further on what you are trying to, the steps you are taking and the resulting behavior.
Thank you.
Amit
2-Explorer
November 8, 2019
See the image below.  It's the "Per Unit Tolerance" check box.  I'm trying to apply a tighter flatness tolerance to an area of a part.
SkyKing10-MarbleAuthor
I guess what the customer has is wrong. Because Creo is more up to date with standards, GD&T is more controlled. Per unit basis not compatible with profile geometric characteristic.
I wish they would just improve things, not change things around!
