why after opening the family table content shows as pipe in groups again?
  • December 8, 2014
  • 1463 views
Dear All,
please check the images that i upload.
Problem is that :
1. first image : I create pipes in model by using family table and then use it in the assembly by calling different part of family table so that the center point what i choose should be same in all.
2.second image : the parameter length is very important for me to be supplied the information in the drawing so I use the formula for calculating length in each family table configuration (image third)
3. When i working in the session (see image 4) problem some same length pipe shown in different item nos. like item 6 & 7 and 9 & 10 and some same length of pipe shown in same like item 8 quantity 2.
4. And when session overs and again open same drawing (see image 5) all pipes convert into one with quantity 6.
i have a big issue after supply this to the fabrication end .
Please help me on this.
Thanks ,
Manish
Best answer by dschenken
Change this relation to calculate after regeneration. It is currently set to Initial (lower right corner of Relations box)
Add the mass properties measurement to the family table and then Verify the family table.
If that doesn't fix the problem, you'll need to contact PTC support for whatever version of software you have to see if there is a version that works correctly.
dschenken1-VisitorAnswer
