Can Creo Illustrate open native Creo Parametric files such as assmblies, parts and drawings?
wfalco
All,
Or does and export file need to be created in Creo Parametrics such as Step?
Wayne
VladimirN
(To:wfalco)
Hello @wfalco
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
llie
(To:wfalco)
@wfalco You cannot directly open a Creo Parametric model in Creo Illustrate. Instead you need to use the Import so it will create a .c3di file from the Creo Parametric model.
If you use Windchill then I would highly recommend using Import, Link.
wfalco
(To:llie)
I'm confused. I go another response to my question saying native files can be opened?
