Creo Illustrate 12.1 loading Performance very bad
  • February 10, 2026
  • 2 replies
  • 165 views
Dear Community,
  • Include which software and version you are using!
    • Creo Illustrate 12.1 - in testing - Creo Illustrate 10.2 productive
    • we skipped Creo Illustrate 11.0 and 11.1 due to troubles with the Admin Tool
  • Explain what you already tried.
    • Comparing Opening / loading times Creo Illustrate 10.2 vs. 12.1 we discovered significant increase in time
      • Creo Illustrate 10.2 - loading appr. 2 Minutes
      • Creo Illustrate 12.1 -  Loading more than 7 Minutes
  • Include a screenshot (Trace file Comparism)
    • If you check the trace files this section calling for a huge time in 12.1
    • Info    15:45:10.319  20 Jan 2026 27668 6500 pvk PvPrefData User preferences saved
      Info    15:45:34.106  20 Jan 2026 27668 6500 Illustrate IllustrateApp Locked file C:/Users/lisher0/Downloads/XXXX.c3di successfully.
      10.2 (24 sec. for this step)
      Info    8:19:13.592  23 Jan 2026 8564 22992 pvk PvPrefData User preferences saved
      Info    8:25:19.803  23 Jan 2026 8564 22992 Illustrate IllustrateApp Locked file C:/Users/lisher0/Downloads/XXXX.c3di successfully.
      12.1 (> 7 Minutes for the same one)
  • Does anybody else identified similar issues with 12.1?
Best answer by rheinz
Hi Adrian,
We did already but were initially disappointed, but we got a hint by the Case owner to respect Article - CS346049 - Creo Illustrate and Windchill PDMLink fail to check in c3di files in direct connection mode, which is not directly the same issue, but looks like blocking since Creo Illustrate 12 also the stand alone client version.
We testing it at the moment and looks like we got the previous performance back, even a bit quicker ...
THX
Robert
Catalina
Community Moderator
February 13, 2026
Hi @rheinz
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina | PTC Community Moderator
I would suggest contacting Tech Support so this issue can be investigated properly.
Information that will be needed:
  • Full set of logs
  • To know if there are any network file systems in use?
  • Were there any anti-virus type tools running?
rheinz13-AquamarineAuthorAnswer
Hi Adrian,
THX
Robert
