Creo Illustrate 2.0 - Annotations button
  • August 29, 2014
  • 2 replies
  • 5781 views
Hello
Some days ago I started working with Creo Illustrate 2.0 M040 and from first moment after installation my Annotations button is unactivated.
Does anybody know what might be the reason?
Wojciech,
It sounds like your callouts template file might have become corrupted. I suggest you delete (or move) your CalloutTemplates.xml file and restart Creo Illustrate to regenerate a new template.
Your CalloutTemplates.xml can be found in:
%APPDATA%\PTC\Illustrate
Hi Tim
I removed the CalloutTemplates.xml file, but after restart Creo Illustrate, the Annotations button still remains inactive.
Tim,
Thank you for your interest in my problem and your suggestions.
Unfortunately, the problem still exists.
I will contact with PTC Tech Support to solve this issue.
Best regards
Wojciech
Hello for everyone
The problem was related with the license.
With the new license this problem does not appear.
