Creo Object Toolkit C++ with Creo Illustrate
  • December 5, 2025
  • 2 replies
  • 189 views
I'm exploring the idea of automatic view creation, where a program would intake a part number of an assembly, highlight it, and export a capture of that part in the assembly and potentially create a view of it. In order to do this, the following would need to be possible:
  • GUI-less API integration with Illustrate
  • API-enabled Camera manipulation
  • API-enabled Part search and manipulation (highlight, color, transparency)
Are any of these possible within Illustrate? Which APIs can work with Illustrate (Web.Link, J-Link, C/C++ Toolkit)?
Best,
Charlie
Best answer by VladimirN
Article - "Is there any API-interface for Creo Illustrate": https://www.ptc.com/en/support/article/CS125540
Quote: "No API is available for Creo Illustrate. This functionality is covered by Idea "Add API/Toolkit functionality to Creo Illustrate": https://community.ptc.com/t5/Creo-View-Illustrate-Schematics/Add-API-Toolkit-functionality-to-Creo-Illustrate/idi-p/905602 "
Community Moderator
December 28, 2025
Hi @CD_14428108,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
VladimirN24-Ruby IIIAnswer
